Articles in this section
Operations with WordPress instance fail in Plesk WP Toolkit: Call to undefined function
Plesk for Linux kb: technical ext: wptk
  • Plesk for Linux
PLESK_ERROR: Failed to reset cache for the instance #568: PHP Fatal error: Uncaught Error: Class 'QodeStartitFramework' not found in /var/www/vhosts/example.com/httpdocs/wp-content/plugins/pluginname
PLESK_ERROR: PHP Warning: Undefined array key "SERVER_NAME" in /var/www/vhosts/example.com/httpdocs/wp-content/plugins/plugin_name/...
Error: Call to undefined function create_function()
Corrupted WordPress plugin.
  1. Log in to Plesk.
  2. Disable the WordPress plugin mentioned in the error message.
    Note: If the corrupted WordPress plugin is required, try to reinstall it. If reinstallation does not help, contact plugin vendor to get further support.
