Articles in this section
After updating to Plesk Obsidian 18.0.81, upgrading a MariaDB server fails: Variable "$releaseId" of required type "String!" was not provided.
kb: bug kb: fixed Plesk for Linux kb: technical
  • Plesk for Linux
  • Plesk was updated to version 18.0.81.
  • When attempting to upgrade MariaDB from 10.5 to version 10.11, 11.8, or 12.3 via the Plesk GUI, the "Analyzing databases with mysqlcheck" stage fails with:
    CONFIG_TEXT: Variable "$releaseId" of required type "String!" was not provided.
    Variable "$databaseServerId" of required type "ID!" was not provided.
Product issue:
  • #PPPM-15531 "Fixed an issue where, after updating to Plesk Obsidian 18.0.81, upgrading a MariaDB server from the “Tools & Settings” > “Database Servers” page failed with the “Variable ‘$releaseId’ of required type ‘String!’ was not provided” error."
    Fixed in:
Workaround
If update is not possible for some reason you may try the following
workaround
Update Plesk to 18.0.81 Update 1 or later.
