Articles in this section
PHP settings do not apply on a domain when CageFS is enabled in CloudLinux
Plesk for Linux kb: technical
  • Plesk for Linux
  • After changing PHP settings in Plesk (for example upload_max_filesize), the new value is not applied on the website phpinfo().
  • Apache logs may contain messages similar to the following:
CONFIG_TEXT: cgi_wrapper: /var/www/vhosts/system/example.com/etc/php.ini: No such file or directory
  • The file exists on the server:
# cat /var/www/vhosts/system/example.com/etc/php.ini | grep upload_max_filesize
upload_max_filesize = 4G
The issue occurs because the CageFS environment for the subscription user is not properly synchronized.
Refresh the CageFS environment for the affected subscription user:
  1. Connect to the Plesk server via SSH.
  2. Disable CageFS for the subscription user
    # cagefsctl --disable example_abcdefgh
  3. Enable CageFS again
    # cagefsctl --enable example_abcdefgh
