Articles in this section
Plesk / system update fails after dist-upgrade from Debian 11 to Debian 12: Depends: libodbc2 (>= 2.3.1) but it is not going to be installed
Plesk for Linux kb: technical
  • Plesk for Linux
  • Debian has been upgraded from 11 (Bullseye) to 12 (Bookworm).
  • Plesk/system update fails with the messages below:
    # apt upgrade
    The following packages have unmet dependencies:
    plesk-librdbmspp : Depends: libodbc2 (>= 2.3.1) but it is not installed
    E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
    plesk-librdbmspp : Depends: libodbc2 (>= 2.3.1) but it is not going to be installed
  • The command apt --fix-broken install fails with:
    CONFIG_TEXT: dpkg: error processing archive /var/cache/apt/archives/libodbc2_2.3.11-2+deb12u1_amd64.deb (--unpack):
    trying to overwrite '/usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0', which is also in package libodbc1:amd64 2.3.11-3
Plesk and system packages cannot be installed/upgraded because old ODBC packages from Debian 11 conflict with the new ODBC packages for Debian 12.
  1. Connect to your Plesk server via SSH.
  2. Remove the conflicting packages:
    # dpkg -r --force-depends libodbc1 odbcinst1debian2 odbcinst
  3. Install/upgrade required system packages:
    # apt --fix-broken install
  4. Update Plesk:
    # plesk installer update
  5. Optional: Upgrade system packages, if necessary:
    # apt upgrade
