Articles in this section
Pages in Plesk interface fail to load periodically: Serialization failure: 1213 Deadlock found when trying to get lock
kb: bug Plesk for Linux kb: technical
  • Plesk for Linux
Pages in Plesk interface fail to load periodically with the message:
PLESK_INFO: ERROR: Plesk\Exception\Database: DB query failed: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction, query was: DELETE FROM 'sessions' WHERE ('modified' + 'lifetime' < 1746777124) (Mysql.php:79)
Plesk bug PPPM-14950.
Until the bug is fixed, apply this workaround:
  1. Connect to your Plesk server via SSH.
  2. Download the custom fix:
    # wget https://support.plesk.com/hc/en-us/article_attachments/32150074671255 -O PPS-17748-custom-fix.tgz
  3. Apply the fix (original files will be renamed):
    # tar -xzvf PPS-17748-custom-fix.tgz -C /usr/local/psa --backup
