Articles in this section
CPU and Memory usage widgets fail to load on Plesk home screen: Request failed with status code 500
Plesk for Linux
  • Plesk for Linux
  • Both CPU and Memory usage widgets display the following error on the Plesk home page:
  • The following error is logged in the Plesk panel log at /var/log/plesk/panel.log:
CONFIG_TEXT: [2024-12-13 23:36:38.197] 467571:675cb6f6300d0 ERR [extension/monitoring] /usr/local/psa/admin/plib/modules/monitoring/library/RrdLib/RrdHeader.php(92): Empty file.
[2024-12-13 23:36:38.239] 467574:675cb6f63a8b8 ERR [extension/monitoring] /usr/local/psa/admin/plib/modules/monitoring/library/RrdLib/RrdHeader.php(92): Empty file
  • Fixing the permissions under  /usr/local/psa/var/health/data/localhost directory with the commands listed below does not fix the issue:
    # find /usr/local/psa/var/health/data/localhost -type f ! -perm 644 | xargs chmod 644
    # find /usr/local/psa/var/health/data/localhost -type d ! -perm 755 | xargs chmod 755
  • The solution the following article does not resolve the issue:
    ▪ Plesk Monitoring thresholds cannot be updated: Request failed with status code 500 – Plesk
The root cause of the issue is unknown.
More information on Jira PPS-17138
In order to resolve the issue, fully remove the Monitoring and Grafana extensions and their relative data and then re-install them. That can be achieved by executing the following steps:
  2. Uninstall Grafana and Monitoring Extensions:
    # plesk bin extension --uninstall grafana
    # plesk bin extension --uninstall monitoring
  3. Remove Grafana from the server completely by executing one of the following commands (based on the operating system):
    ▪ For Debian-based operating systems:
    # apt purge grafana && rm -rf /usr/share/grafana /etc/grafana /var/lib/grafana
    ▪ For RHEL-based operating systems:
    # yum remove grafana && rm -rf /usr/share/grafana /etc/grafana /var/lib/grafana
  4. Delete the folder /usr/local/psa/var/health/data and its content:
    # rm -rf /usr/local/psa/var/health/data
  5. Reinstall Grafana and Monitoring Extensions:
    # plesk bin extension --install grafana
    # plesk bin extension --install monitoring
  6. Restart sw-collectd to regenerate stat files:
    # systemctl restart sw-collectd
