Plesk is inaccessible
Server Error
500 Plesk\Exception\Database
DB query failed: SQLSTATE[HY000] [2002] Connection refused -
The MariaDB logs show that the process was terminated by the out-of-memory (OOM) killer
# journalctl -xeu mariadb.service
The process' exit code is 'killed' and its exit status is 9.
mariadb.service: Failed with result 'oom-kill'.
Subject: Unit failed -
The system has no swap configured or is running out of memory
# free -h
total used free shared buff/cache available
Mem: 1.8Gi 796Mi 158Mi 236Mi 908Mi 646Mi
Swap: 0B 0B 0B
The server doesn't have enough free memory for MariaDB, so it terminates the process to prevent a server crash.
To fix the problem, more memory needs to be made available to MariaDB. Some options are:
Note: Reach out to the hosting provider or system administrator if assistance is needed with these steps
- Configure swap to use as backup memory: How to create a swap file on a Plesk Linux
- Increase the amount of RAM on the server
