Site Import fails with ModuleNotFoundError: No module named 'urllib2'
CONFIG_TEXT: command: su jdoe --shell /bin/sh -c '/usr/local/psa/admin/plib/modules/site-import/backend/lib/python/parallels/core/extras/web-stream-downloader/web-stream-downloader --config-file -'
exit code: 1
stdout:
stderr: Traceback (most recent call last):
File "/usr/local/psa/admin/plib/modules/site-import/backend/lib/python/parallels/core/extras/web-stream-downloader/web-stream-downloader", line 3, in [module]
from web_stream_downloader.main import main
File "/opt/psa/admin/plib/modules/site-import/backend/lib/python/parallels/core/extras/web-stream-downloader/web_stream_downloader/main.py", line 4, in [module]
import urllib2
Product issue:
#PMT-5363 "Site import no longer fails with the âNo module named /âurllib2/ââ error."
Fixed in:- Site Import 1.8.4 15 August 2024
Workaround
If update is not possible for some reason you may try the following
Update Plesk to the latest release.
