Articles in this section
Plesk interface on Plesk Onyx 17.5 and earlier is not accessible: syntax error, unexpected ':', expecting ';' or '{' (WelcomePanelTrait.php:15)
Plesk for Linux kb: technical
Plesk interface on servers with Plesk Onyx 17.5 and earlier is not accessible:
ERROR: syntax error, unexpected ':', expecting ';' or '{' (WelcomePanelTrait.php:15)
Bug EXTPLESK-5618.
The bug is already fixed, the issue will be resolved after the next execution of the Plesk daily task.
The execution of the Plesk daily task for resolving the issue can be forced as follows:
  1. Connect to the server using SSH.
  2. Execute the command:
    # plesk daily UpgradeExtensions
