kb: technical
linux
plesk for linux
The following error messages are shown in Tools & Settings > Diagnose & Repair:
CONFIG_TEXT: ERROR
There are incorrect permissions on some items: /var/log/plesk
ERROR
There are incorrect permissions on some items: /opt/psa/PMM/tmp
ERROR
There are incorrect permissions on some items: /opt/psa/PMM/rsessions
ERROR
There are incorrect permissions on some items: /var/log/plesk/PMM
Incorrect permissions. It's possible change happened due to a 3rd-party script or program.
- Connect to the server via SSH
Fix the permission by executing the following command:
# plesk repair fs -system
Il comando plesk repair fs -system non ha risolto il problema, restituendo il seguente esito:
Error messages: 1; Warnings: 0; Errors resolved: 0
Exit status: 1.
