Articles in this section
Spamassassin rules update causes missing modules error: Can't locate Mail/SpamAssassin/CompiledRegexps/body_neg2000.pm
kb: technical
  • Spamassassin rules update causes missing modules error in /var/log/maillog:
    spamd[92075]: Can't locate Mail/SpamAssassin/CompiledRegexps/body_neg2000.pm in @INC (you may need to install the Mail::SpamAssassin::CompiledRegexps::body_neg2000 module) (@INC contains: /var/lib/spamassassin/compiled/5.030/3.004004 /var/lib/spamassassin/compiled/5.030/3.004004/auto /usr/share/perl5 /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.30.0 /usr/local/share/perl/5.30.0 /usr/lib/x86_64-linux-gnu/perl5/5.30 /usr/lib/x86_64-linux-gnu/perl/5.30 /usr/share/perl/5.30 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at (eval 2046) line 1.
    spamd[92075]: zoom: able to use 341/372 'body_0' compiled rules (91.666%)
This has been reported as bug ID PPPM-14367.
Component installation on Debian-based systems installs sa-compile package as a Recommends dependency of SpamAssassin.
It brings in /etc/spamassassin/sa-compile.pre configuration with loadplugin Mail::SpamAssassin::Plugin::Rule2XSBody which actually causes these diagnostic messages.
For Debian-based systems (include Ubuntu)
  2. Remove sa-compile
    # apt-get purge sa-compile
For any system (Include RedHat/Debian-based)
  2. Use vi or any text editor to comment out the line loadplugin Mail::SpamAssassin::Plugin::Rule2XSBody in /etc/mail/spamassassin/ for RedHat-based systems or under /etc/spamassassin for Debian-based systems. Add # at the beginning of the line as below:
    # loadplugin Mail::SpamAssassin::Plugin::Rule2XSBody
