kb: technical
An attempt to access Plesk login page at
http://203.0.113.1:8443results in the following error:Server Error
500 Plesk\Exception\Database
DB query failed: SQLSTATE[HY000] [2002] Connection refused Type Plesk\Exception\Database
Message DB query failed: SQLSTATE[HY000] [2002] Connection refused
File Mysql.php
Line 79 -
Mariadb service is not started
# systemctl status mariadb.service
○ mariadb.service - MariaDB 10.6.21 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor prese>
Active: inactive (dead)
Plesk user interface requires mariadb.service to be up and running to load properly.
2. Start MariaDB with the following command:
# systemctl start mariadb.service
