Articles in this section
Plesk interface is down or slow: server reached max_children setting
Plesk for Linux kb: technical
  • Plesk for Linux
  • Plesk is inaccessible with one of the following errors:
    DB query failed: SQLSTATE[HY000] [2002] Resource temporarily unavailable
    Type Plesk\Exception\Database
    Message DB query failed: SQLSTATE[HY000] [2002] Resource temporarily unavailable
    File Mysql.php
    Line 60
    Server Error
    502 Bad Gateway
    Web server received an invalid response while acting as a gateway or proxy server.
  • These errors are logged to /var/log/plesk/sw-cp-server/sw-engine.log:
    [pool plesk] server reached max_children setting (26), consider raising it
The Plesk panel reached its pm.max_children limit.
Increase the limit.
  1. Log in via SSH
  2. Increase the pm.max_children value in /etc/sw-engine/pool.d/plesk.conf:
    # sed -i.bkp 's/max_children.*/max_children\ =\ 50/' /etc/sw-engine/pool.d/plesk.conf
    Note: The command above increases the limit to 50. Increase it further if the error continues.
  3. Restart sw-engine in order to apply the changes:
    # service sw-engine restart
