Plesk for Linux
kb: technical
While executing the
plesk repair installationutility on a Linux server, an error that is similar to the following appears:CONFIG_TEXT: Errors occurred while performing the following actions: fix Plesk packages permissions.
Incorrect permissions or ownership on files tied to Plesk packages are preventing the repair utility from working as expected.
- Connect to the server via SSH
Fix the permissions by executing the following command:
# plesk sbin fsmng --fix-plesk-packages
