Articles in this section
Domain creation/removal task is stuck in Plesk
kb: technical
  • Plesk for Linux
  • Plesk for Windows
  • Domain creation task is stuck in Plesk.
  • The task has a "not_started" status in psa.longtasks database table:
    # plesk db "SELECT id,type,status,finishTime FROM longtasks WHERE status <> 'done'"
    | id | type | status | finishTime |
    | 88282| domain-create | not_started | 0000-00-00 00:00:00 |
Unclear.
For Plesk on Linux
  1. Connect to your Plesk server via SSH.
  2. Created a backup of the Plesk database:
    # plesk db dump psa > /root/psa.sql
  3. Find the ID of the stuck task that has status "not_started" (in this example, it is 88282):
  4. Using the ID, remove this task from longtasks and longtaskparams database tables:
    # plesk db "DELETE FROM longtasks WHERE id=88282"
    # plesk db "DELETE FROM longtaskparams WHERE task_id=88282"
  5. Restart the the Plesk Task Manager service:
    # service plesk-task-manager restart
For Plesk on Windows Server
  1. Connect to your Plesk server via RDP.
  2. Start a command prompt as an Administrator.
  3. Created a backup of the Plesk database:
    C:\> plesk db dump psa > C:\psa_dump.sql
  4. Find the ID of the stuck task that has status "not_started" (in this example, it is 88282):
    C:\> plesk db "SELECT id,type,status,finishTime FROM longtasks WHERE status <> 'done'"
  5. Using the ID, remove this task from longtasks and longtaskparams database tables:
    C:\> plesk db "DELETE FROM longtasks WHERE id=88282"
    C:\> plesk db "DELETE FROM longtaskparams WHERE task_id=88282"
  6. Restart the the Plesk Task Manager service:
    C:\> net stop PleskTaskManager && net start PleskTaskManager
