Articles in this section
Issuing a Let's Encrypt certificate in Plesk fails when using external DNS: DNS problem: SERVFAIL looking up CAA for example.com
kb: technical ext: sslit
  • An attempt to issue a Let's Encrypt certificate in Plesk fails with the following error:
    CONFIG_TEXT: Invalid response from https://acme-v02.api.letsencrypt.org/acme/finalize/170110130/120505529288.
    Details:
    Type: urn:ietf:params:acme:error:caa
    Status: 403
    Detail: Error finalizing order :: While processing CAA for example.com: DNS problem: SERVFAIL looking up CAA for example.com - the domain's nameservers may be malfunctioning
  • External DNS service is being used to host the domain DNS Zone.
External DNS server does not process CAA requests correctly and SERVFAIL is returned instead of NOERROR.
  • Contact DNS server administrator to address the issue.
As workaround:
  • Add a CAA record like below example into the externally hosted domain DNS zone:
    CONFIG_TEXT: example.com. CAA 0 issue "letsencrypt.org"
