Unable to issue the Let's Encrypt certificate:
CONFIG_TEXT: Detail: Order's status ("pending") is not acceptable for finalization
This is a Plesk bug with the ID EXTPLESK-10225, fixed in Plesk Obsidian 18.0.82.
- Log into Plesk
- Install Plesk updates to Plesk Obsidian 18.0.82 or later
- Reissue the Let's Encrypt SSL certificate at Domains > example.com > SSL/TLS Certificates
Click the section to expand
If updating Plesk is not possible yet, apply the following workaround:
- Log into the server via SSH
Search for the file under
/usr/local/psa/var/modules/letsencrypt/ordersusing the domain name:# grep -r "example.com" /usr/local/psa/var/modules/letsencrypt/orders
/usr/local/psa/var/modules/letsencrypt/orders/73e9346c3fc065d13305183342f962c17b0bed5c.json -
Note: Replace 73e9346c3fc065d13305183342f962c17b0bed5c.json with the file name found in the output of the command on step 2.
Create a backup copy of the file:
# cp -a /usr/local/psa/var/modules/letsencrypt/orders/73e9346c3fc065d13305183342f962c17b0bed5c.json /root/
Remove the JSON files found in the output of the command on step 2:
# rm -f /usr/local/psa/var/modules/letsencrypt/orders/73e9346c3fc065d13305183342f962c17b0bed5c.json
- Log into Plesk
I am experiencing this issue on Plesk Obsidian with SSL It! 1.23.0 and Let's Encrypt 3.5.0.
This is a mail-only domain. The website is hosted elsewhere and the authoritative DNS is hosted by Cloudflare, so I need to use DNS-01 to secure:
mail.mydomain.comwebmail.mydomain.comSSL It! successfully creates the DNS-01 challenges, but after the required TXT records have been added and are publicly resolvable, the order remains permanently in pending status.
I confirmed the TXT records were visible from:
1.1.1.18.8.8.8Despite this, running:
plesk ext sslit --certificate -issue -domain mydomain.com -continuerepeatedly returned:
status: pendingInspection of the Let's Encrypt order JSON showed both DNS challenges remained:
"isPerformed": true"isConfirmed": falseI completely cancelled and removed the original order, cleared the stale order data and created a brand-new certificate order. Plesk generated new DNS-01 TXT values, which were again added to Cloudflare and verified as publicly resolvable. The new order exhibited exactly the same behaviour and remained pending with
isConfirmed:false.To rule out Cloudflare, DNS propagation and Let's Encrypt itself, I then installed Certbot on the same Plesk server and requested a certificate for exactly the same two hostnames using a manual DNS-01 challenge.
Certbot successfully issued the Let's Encrypt certificate immediately once the TXT records were present.
I imported that certificate into Plesk and assigned it to the domain. It is now working correctly for both IMAP and webmail.
This therefore appears to be a reproducible problem with Plesk/SSL It!'s DNS-01 challenge continuation/confirmation rather than an external DNS or Let's Encrypt problem.
This is particularly problematic for mail-only Plesk servers, where the customer's website is hosted elsewhere and HTTP-01 may not be available. DNS-01 is therefore not an edge case for this type of configuration.
It would be useful to know when #EXTLETSENC-1169 is expected to be fixed, as the current workaround leaves certificates issued manually outside Plesk and therefore prevents Plesk from handling their normal automatic renewal.
