Articles in this section
A website hosted in Plesk fails to load: ModSecurity: Response body too large
Plesk for Linux kb: technical
  • Plesk for Linux
  • A website is not loading with the following error message in a web browser:
    PLESK_INFO: 500
    Internal Server Error
  • The following messages are logged in Domains > example.com > Logs:
    CONFIG_TEXT: [error] [client 203.0.113.2] ModSecurity: Output filter: Response body too large (over limit of 524288, total not specified). [hostname "www.example.com"] [uri "/index.php"] ...
The website has exceeded default ModSecurity SecResponseBodyLimit parameter (1 MB).
Adjusting 'SecResponseBodyLimit' for one domain
  1. Log in to Plesk.
  2. Go to Domains > example.com > Hosting & DNS > Apache & nginx Settings.
  3. Add the line below to Additional directives for HTTP and Additional directives for HTTPS fields to increase SecResponseBodyLimit to 256 MB (or define your own value):
    CONFIG_TEXT: <IfModule mod_security2.c>
        SecResponseBodyLimit 268435456
    </IfModule>
  4. Apply the changes.
Adjusting 'SecResponseBodyLimit' for all domains
  1. Log in to Plesk.
  2. Go to Tools & settings > Web Application Firewall (ModSecurity) > Settings tab. > Custom directives section:
  3. Add the line below to Custom directives section to increase SecResponseBodyLimit to 256 MB (or define your own value):
    CONFIG_TEXT: SecResponseBodyLimit 268435456
1 comment
Date Votes
  • The for all domains code still works, the for one domain version causes errors on the site….
    Maybe an update of the code is needed?
