Articles in this section
Various operations fail in Plesk: Failed to read data from stream Process output
Plesk for Linux
  • Plesk for Linux
  • When opening Plesk Backup Manager or removing a domain in Plesk, the operation fails with:
    PLESK_INFO: Internal Error: Failed to parse response. Reason: Failed to read data from stream Process output
  • When creating a domain in Plesk, the operation fails with:
    PLESK_INFO: Creating physical hosting
    phpinimng failed: Traceback (most recent call last):
    ImportError: cannot import name 'sysconfig' from 'distutils' (/usr/lib/python3.7/distutils/__init__.py):
  • The pmmcli utility fails with "ImportError":
    # /usr/local/psa/admin/bin/pmmcli --help
    ImportError: No module named libxml2
    ImportError: cannot import name 'etree' from 'lxml' (/usr/lib/python3/dist-packages/lxml/__init__.py)
/usr/bin/python3 is linked to a non-default Python version.
  1. Connect to the Plesk server via SSH.
  2. Remove the invalid link:
    # unlink /usr/bin/python3
  3. Link /usr/bin/python3to /usr/bin/python3.6:
    # ln -s /usr/bin/python3.6 /usr/bin/python3
