Articles in this section
Notifications from Built-in Monitoring in Plesk: [Alerting] Partition "/" utilization
Plesk for Windows Plesk for Linux kb: technical Plesk Obsidian ABT: Group A
  • Plesk for Linux
  • Plesk for Windows
What should be performed if I receive a notification from Monitoring about critical disk usage:
CONFIG_TEXT: Monitoring
[Alerting] Disk "C:\" utilization
Such notification appears when system resource (Disk usage) reached value configured in Monitoring > Settings > Thresholds:
By default defined threshold value is 80%:
There are two possible situations for this to appear:
  1. The partition (disk) utilization is expected but the threshold is set too low.
    In this case, increase the threshold value for disk utilization in Monitoring > Settings > Thresholds and click Apply
  2. The partition (disk) utilization is unexpected and requires additional actions:
Plesk for Linux:
If required, increase the disk space of the server and resize partitioning.
Warning: Disk partitioning is not covered by Plesk Technical Support. If you are not familiar with Linux system administering and would like Plesk professionals to handle this task, please contact Plesk Professional Services team.
If Plesk server is running in a Virtuozzo container (the file /proc/user_beancounters exists on the server), the inode limit can be increased as described in the Virtuozzo article. If you are a container owner, contact your service provider for assistance.
If Plesk server is running in a Vultr virtual machine, it is possible to resize the hard disk of the machine using the official Vultr documentation.
Plesk for Windows:
