Articles in this section
Plesk is not accessible with error 500: Failed opening required
Plesk for Windows kb: technical
  • Plesk for Windows
  • Plesk is not accessible with error 500.
  • The following error is found in C:\Program Files (x86)\Plesk\admin\logs\php_error.log:
    PHP Fatal error: require_once(): Failed opening required 'C:\Program Files (x86)\Plesk\admin\plib/vendor/autoload.php' (include_path='C:\Program Files (x86)\Plesk\admin\plib') in C:\Program Files (x86)\Plesk\admin\plib\Loader.php on line 20
    'C:\Program Files (x86)\Plesk\admin\plib\cu\admin.php' is not recognized as an internal or external command, operable program or batch file.
  • Running Plesk commands fail with the following error:
    C:\Users\Administrator> plesk login -support
    at (RunTime::Execute::commandLine line 595)
    at Unable to execute CU(wmain line 64)exit status 1
    Note: Other commands like plesk bin <script> leads to the same error
Corrupted Plesk installation / Antivirus software interfering with Plesk functionality.
  1. Connect to the server via RDP
  2. Open Plesk Service Monitor and stop Plesk Management Service
  3. Create a copy of your admin folder in C:\Program Files (x86)\Plesk into a different location like C:\
  4. Download plesk-core.zip from https://autoinstall-win.plesk.com/, extract and substitute files under %plesk_dir%admin\plib.
    Note: As an example, if Plesk is version 18.0.72, the plesk-core.zip file is located in https://autoinstall-win.plesk.com/PANEL-WIN_18.0.72/dist-windows/
  5. Enable back Plesk Management Service from Plesk Service Monitor
To avoid this to happen again, add %plesk_dir% to exceptions on antivirus.
