Plesk is not accessible:
CONFIG_TEXT: 502 Bad Gateway
The service
sw-engineis down:# systemctl status sw-engine -l
plesk.example.com systemd[1]: Starting Startup script for Panel sw-engine...
plesk.example.com sw-engine-fpm[17102]: ERROR: failed to open error_log (/var/log/sw-cp-server/sw-engine.log): No such file or directory (2)
plesk.example.com sw-engine-fpm[17102]: ERROR: failed to post process the configuration
plesk.example.com sw-engine-fpm[17102]: ERROR: FPM initialization failed
plesk.example.com systemd[1]: sw-engine.service: main process exited, code=exited, status=78/n/a
plesk.example.com systemd[1]: sw-engine.service stop-sigterm timed out. Killing.
plesk.example.com systemd[1]: Failed to start Startup script for Panel sw-engine.
plesk.example.com systemd[1]: Unit sw-engine.service entered failed state.
plesk.example.com systemd[1]: sw-engine.service failed.
The log file /var/log/sw-cp-server/sw-engine.log does not exist on the server.
Connect to the server using SSH.
Re-create the log directory if it does not exist:
# if [ ! -d "/var/log/sw-cp-server" ]; then mkdir /var/log/sw-cp-server && chmod 750 /var/log/sw-cp-server; fi
Re-create the missing log file:
# touch /var/log/sw-cp-server/sw-engine.log && chmod 600 /var/log/sw-cp-server/sw-engine.log
Start
sw-engine:# service sw-engine start
