Articles in this section
How to repair website MySQL/MariaDB databases and tables in Plesk?
Plesk for Windows kb: how-to Plesk for Linux ABT: Group A
  • Plesk for Windows
  • Plesk for Linux
  • How to repair non-InnoDB MySQL/MariaDB tables on Plesk server?
  • How to repair domain MySQL/MariaDB databases and tables in Plesk?
  1. Log into Plesk
  2. Go to Domains > example.com > Databases and click Check and Repair for the required database
Command-line solution
Linux-based operating systems:
  1. Connect to server over SSH
  2. Execute the below command substituting required table and database:
    # MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysqlcheck <database name> <table name> --repair -u admin
Windows-based operating systems
  1. Connect to server via RDP
  2. Open command-line console cmd.exe with Administrator privileges.
  3. Execute below command substituting required table and database:
    MYSQL_WIN: C:>"%plesk_dir%MySQL\bin\mysqlcheck" -P3306 -uadmin -p -r <database name> <table name>
    If the password is unknown, reset it according to this KB article.
Not all the storage engines in MySQL//MariaDB database support repair of the tables. If storage engine does not support repair the following message will appear:
CONFIG_TEXT: The storage engine for the table doesn't support repair
In such a case, follow the instructions provided in the article: How to fix InnoDB corruption cases for the MySQL database?
Additional Information
How to access MySQL databases?
1 comment
Date Votes
  • Hi Benjamin Weßel,
    May I ask how would you do so for all tables, or, how would you know which table to fix, and how to set it in the recommended CLI?
    1
