- Plesk for Windows
How to change the IP address for a domain / all domains in Plesk?
Note: In Plesk, domains assigned to a subscription will have IP address of this subscription. It is not possible to have domains with different IP addresses under one subscription.
- Log in to Plesk.
- Go to Domains > example.com > Hosting & DNS tab > Hosting.
- Scroll down to the IP Addresses section and select the required IP address.
Click Save to apply the changes.
Command-line instructions:
Execute the following command:
to change IPv4 only:
# plesk bin subscription --update example.com -ip 203.0.113.3
where:
example.com- domain name -
203.0.113.3- new IP address
to change IPv4 and IPv6:
# plesk bin subscription --update example.com -ip 203.0.113.3,2001:db8:f61:a1ff:0:0:0:80
where:
203.0.113.3- new IP address -
2001:db8:f61:a1ff:0:0:0:80- new IPv6 address
Generate a list of all subscriptions:
# plesk bin subscription --list > /root/subscriptions.txt
(Optional) Open the file
/root/subscriptions.txtin a text editor and remove subscriptions, IP address of which should not be changed. -
# cat /root/subscriptions.txt | while read i; do plesk bin subscription -u $i -ip 203.0.113.3 ; done
where:
# cat /root/subscriptions.txt | while read i; do plesk bin subscription -u $i -ip 203.0.113.3,2001:db8:f61:a1ff:0:0:0:80 ; done
where:
Connect to the Plesk server via RDP.
Start PowerShell as an Administrator.
PS plesk bin subscription -l > C:\subscriptions.txt
(Optional) Open
C:\subscriptions.txtand remove subscriptions, IP address of which should not be changed. -
PS more C:\subscriptions.txt | % { if ($_) { plesk bin subscription --update $_ -ip 203.0.113.3 } }
where:
PS more C:\subscriptions.txt | % { if ($_) { plesk bin subscription --update $_ -ip 203.0.113.3,2001:db8:f61:a1ff:0:0:0:80 } }
where:
In the example below, the subscriptions that are assigned to IP address 203.0.113.2 will be switched to new IP address 203.0.113.4.
Note: In case there are resellers using IP address 203.0.113.2, launching the command below will lock them and they will not synchronize with their Service Plans.
Generate a list of all subscriptions which are currently assigned to a specific IP address (in this example, it is 203.0.113.2):
# plesk db -Ne "select d.name from IP_Addresses ipa join IpAddressesCollections ipac on ipac.ipAddressId=ipa.id join DomainServices ds on ds.ipCollectionId=ipac.ipCollectionId join domains d on d.id=ds.dom_id join Subscriptions s on s.object_id=d.id where ds.type='web' and ipa.ip_address='203.0.113.2'" > subscriptions.txt
Assign te new IP address to all subscriptions listed in
subscriptions.txtfile:# while read i; do plesk bin subscription -u $i -ip 203.0.113.3; done < subscriptions.txt
