- Plesk for Windows
Unable to open Site Preview, it redirects to another URL with one of the following errors:
CONFIG_TEXT: HTTP Error 404.4 - Not Found
The resource you are looking for does not have a handler associated with it.
Error Code: 0x8007007b
CONFIG_TEXT: HTTP Error 404.0 - Not Found
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.
Error Code: 0x80070002 -
When Default Quick Preview is set in Tools & Settings > Website Preview the following error is shown in Plesk UI:
PLESK_ERROR: ERR [panel] websrvmng failed: Site sitepreview doesn't exist
at (WebServerMap::get line 189)
at startHosting(sitepreview)(WebServerAdapter::startHosting line 772)
at execute console command --start-vhost(vconsoleapp::start line 122)
at execute "C:\Program Files (x86)\Plesk\admin\bin64\websrvmng" --start-vhost "--vhostname=sitepreview"(vconsoleapp::run line 139)
(Error code 1)
Site preview misconfiguration.
Connect to the server via RDP.
Open Windows Command Prompt (CMD) as Administrator.
Reconfigure site preview using the following command:
C:\> "%plesk_cli%\repair.exe" --reconfigure-site-preview
