Articles in this section
How to add custom locale to Plesk?
kb: how-to Plesk for Linux ABT: Group B
How to add a new locale (create custom language files) in Plesk?
In the examples below, the English 'en-US' locale is used as the source, and the Czech 'cs-CZ' locale is used as the new target.
  1. Log into the server via SSH.
  2. Copy the existing locale directories (e.g., 'en-US') to the new locale path (e.g., 'cs-CZ'):
    CONFIG_TEXT: cp -npr /usr/local/psa/admin/application/admin/resources/languages/en-US/ /usr/local/psa/admin/application/admin/resources/languages/cs-CZ/ cp -npr /usr/local/psa/admin/application/default/resources/languages/en-US/ /usr/local/psa/admin/application/default/resources/languages/cs-CZ/ cp -npr /usr/local/psa/admin/plib/locales/en-US/ /usr/local/psa/admin/plib/locales/cs-CZ/ cp -npr /usr/local/psa/admin/application/smb/resources/languages/en-US/ /usr/local/psa/admin/application/smb/resources/languages/cs-CZ/
  3. Rename the files inside the new directory according to the locale code:
    CONFIG_TEXT: cd /usr/local/psa/admin/plib/locales/cs-CZ rename 's/en-US/cs-CZ/' *
    Note: If the rename command is not available or works differently on your OS (e.g., CentOS), you may need to use the mv command to rename files manually.
  4. Modify the messages_*.php file to replace the locale string:
    CONFIG_TEXT: sed -i 's/en-US/cs-CZ/g' ./messages_cs-CZ.php
  5. Modify (or create) the meta.xml file to reflect the locale name in the Plesk UI:
    CONFIG_TEXT: vi /usr/local/psa/admin/plib/locales/cs-CZ/meta.xml
    The file content should look as follows:
    CONFIG_TEXT: <?xml version="1.0" encoding="utf-8"?> <!-- Copyright 1999-2017. Parallels IP Holdings GmbH. All Rights Reserved. --> <locale> <language>Česky</language> <country>Czech</country> </locale>
    Note: Custom language and country names should be placed inside <language> and <country> tags.
  6. Register the new locale in the Plesk database:
    CONFIG_TEXT: plesk db "replace into locales values ('cs-CZ', 'true');"
  7. Modify the files according to language specifics. When logged in using the new locale, GUI items will be reflected accordingly.
For more information check the Plesk localization guide.
