- Plesk for Windows
How to enable / disable debug logging in Plesk?
Note: Debug mode can be enabled either via the Plesk Panel.ini Editor extension in Plesk or in the Plesk configuration file "panel.ini" directly on a Plesk server.
Note: In Plesk for Linux, debug log entries are written to Plesk logfile /var/log/plesk/panel.log. Also, when running Plesk utilities with debug mode enabled in a command-line interface, they will produce debug log entries in their output.
In Plesk for Windows Server, debug log entries are written to Plesk logfile %plesk_dir%admin\logs\php_error.log.
Warning: Debug mode can consume a large amount of disk space over time. Once you are done troubleshooting, disable debug mode.
- Log in to Plesk.
- Install the Panel.ini Editor from the Extensions menu in Plesk.
- Open Panel.ini Editor at Extensions > My Extensions.
In Panel.ini Editor, switch to the Editor tab.
If the editor is empty, apply the following steps:
4.1. Download the panel_ini.txt file.
4.2. Open the downloaded file and copy its content.
4.3. Paste the content into the editor.
Edit the content and click Save:
- To enable debug mode, remove a semicolon ";" at the beginning of the lines highlighted on the picture.
- To disable debug mode, put a semicolon ";" back at the beginning of the lines.
- Connect to a Plesk server via SSH.
Сheck if the "panel.ini" configuration file exists:
# ls -l /usr/local/psa/admin/conf/panel.ini
If the file
/usr/local/psa/admin/conf/panel.inidoes not exist or is empty, create it from the sample file/usr/local/psa/admin/conf/panel.ini:# cp /usr/local/psa/admin/conf/panel.ini.sample /usr/local/psa/admin/conf/panel.ini
Open the file
/usr/local/psa/admin/conf/panel.iniin a text editor. In this example, we are using the vi editor and the command:# plesk conf panel.ini
Edit the
panel.inifile:- To enable debug mode, remove a semicolon ";" at the beginning of the bold lines shown in the example below.
- To disable debug mode, put a semicolon ";" back at the beginning of the bold lines.
Example of enabled debug mode:
CONFIG_TEXT: [debug]
; Enable debug mode (do not use in production environment)
enabled = on
[log]
; Log messages verbosity level (from 0 to 7)
; 0 - only critical errors, 7 - all including debug messages, default - 3
filter.priority = 7
; Enable logging of SQL queries
show.sql_query = on
; Enable logging of external utilities calls
show.util_exec = on
; Enable logging of stdin and stdout for external utilities calls (do not use in production environment)
show.util_exec_io = on
[ext-wp-toolkit]
logSecurityCheckErrors = on
logExceptionStackTraces = on - Save the changes and close the file. The changes will be applied immediately, no service restart is required.
Example of Plesk utility output when debug mode is enabled:
# /usr/local/psa/bin/ip_ban --update -ban_period 600 -ban_time_window 600 -max_retries 10
DEBUG [dbquery] [0] SQL: SET sql_mode = ''
DEBUG [dbquery] [0] END: 0.00023102760314941 sec
DEBUG [dbquery] [1] SQL: SET NAMES utf8
DEBUG [dbquery] [1] END: 0.00013208389282227 sec
DEBUG [dbquery] [2] SQL: connect
DEBUG [dbquery] [2] END: 0.00038313865661621 sec
DEBUG [dbquery] [3] SQL: SET sql_mode = ''
DEBUG [dbquery] [3] END: 0.00014400482177734 sec
SUCCESS: The settings were updated. -
Example of Plesk utility output when debug mode is disabled:
- Connect to a Plesk server via RDP.
- Open the file
panel.inilocated in the folder%plesk_dir%admin\conf\(Just paste this path in Windows Explorer to open) in any text editor.- If the
panel.inifile does not exist, create it by copying the sample configuration filepanel.ini.sample.
- If the
Edit the
- To disable debug mode, put a semicolon ";" back in the lines.
enabled = on
[log]
filter.priority = 7
show.sql_query = on
show.util_exec = on
[ext-wp-toolkit]
logExceptionStackTraces = on - Save the changes and close the file. Changes will be applied immediately, no service restart is required.
