Unable to upload a file using a web application or webmail, the following error is shown:
An error occurred!
File upload failed -
On uploading a big file via WordPress administrator interface, the following error is shown:
Unexpected response from the server. The file may have been uploaded successfully. Check in the Media Library or reload the page.
The following error can be seen in the browser's console:
413 Request Entity Too Large
Uploading of big size file fails with the following error in
/var/www/vhosts/system/example.com/logs/proxy_error_log
or/var/log/nginx/error.log
file:client intended to send too large body: 163625628 bytes, client: 203.0.113.2, server: example.com, request: "POST /attachments/uploading.json?hash=bb192e03d44f11110881f1c148ef629&content_type=resource_version&key=resource HTTP/1.1", host: "203.0.113.2", referrer: "https://203.0.113.2/resources/add?resource_category_id=13"
Webserver limits maximum filesize to be uploaded.
Note: The following solution increases the limit server wide.
Adjust the following settings of PHP handler assigned to the domain in Tools & Settings > PHP Settings > X.X.XX FPM application in php.ini tab:
post_max_size 2000m
upload_max_filesize 2000m -
Perform the following steps depending on the webserver serving PHP in Domains > example.com > PHP Settings:
For case PHP is served by nginx-
Add the following directives to
/usr/local/psa/admin/conf/panel.ini
file using 'vi' utility to customize Plesk defaults:[webserver]
nginxClientMaxBodySize = 2000mNote: If file
does not exist, create it from the sample file with this command:# cp /usr/local/psa/admin/conf/panel.ini.sample /usr/local/psa/admin/conf/panel.ini
Rebuild web server configuration files:
# plesk repair web -domains-only
Reload nginx:
# service nginx reload
For case PHP is served by Apache-
Backup the main Apache configuration file:
On RedHat/CentOS/CloudLinux operating systems:
# cp /etc/httpd/conf/httpd.conf{,.orig}
On Debian/Ubuntu operating systems:
# cp /etc/apache2/apache2.conf{,.orig}
Open the file from step 1. and add or modify the parameter
LimitRequestBody
to the required value in bytes, for example:LimitRequestBody 2147483647
Note: The maximum value of the parameter LimitRequestBody is 2147483647 (2 gigabytes).
Go to Domains > example.com > Hosting & DNS > Apache & nginx Settings and set Maximum allowed HTTP request body size to desired value, e.g. 2GB.
Click OK/Apply.
