- The following error message is shown in Plesk when:
- downloading/uploading/opening a large backup file in Backup Manager
importing/exporting a large database dump
PLESK_INFO: 504 Gateway Time-out
upgrading MariaDB in Tools & Settings > Database Servers
PLESK_ERROR: Response not successful: Received status code 504.
When archiving (zipping) a large amount of data, the operation fails with:
PLESK_ERROR: Internal error: SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
PLESK_ERROR: Internal error: SyntaxError: Unexpected token < in JSON at position 0
The following error message is logged in
/var/log/sw-cp-server/error_log:CONFIG_TEXT: [error] 37325#0: *273172 upstream timed out (110: Connection timed out) while reading response header from upstream
Timeout limit which is set up in Plesk configuration has been exceeded by the operation.
- Connect to your Plesk server via SSH.
Modify the file
/etc/sw-cp-server/config:2.1. Open the file in a text editor. In this example we are using vi editor:
# vi /etc/sw-cp-server/config
2.2. Increase the value of
fastcgi_read_timeoutandfastcgi_send_timeoutto 1200 (20 minutes):CONFIG_TEXT: fastcgi_read_timeout 1200;
fastcgi_send_timeout 1200;2.3. Save the changes and close the file.
Modify the file
/usr/local/psa/admin/conf/php.ini:3.1. Open the file in a text editor:
# vi /usr/local/psa/admin/conf/php.ini
3.2. Increase the
max_execution_timevalue to 1200:CONFIG_TEXT: max_execution_time 1200
3.3. Save the changes and close the file.
Restart Plesk services:
# service sw-cp-server restart && service sw-engine restart
- Retry the failed operation.
