Articles in this section
How to cancel a stuck task in Plesk
Plesk for Windows kb: how-to Plesk for Linux
  • Plesk for Linux
  • Plesk for Windows
A task (scheduled task, WordPress installation, extension update, etc.) is stuck in Plesk. How to stop this stuck task and close the "tasks in progress" window?
Plesk for Linux
Cancelling a single task
  1. Connect to your Plesk server via SSH.
  2. Create a backup of the Plesk database:
    # plesk db dump > /root/psa_dump_for_kb_12377460333463.sql
  3. List the stuck process:
    # plesk db "SELECT id,type,status,finishTime FROM longtasks WHERE status <> 'done'"
    | id | type                        | status  | finishTime          |
    | 56 | ext-wp-toolkit-task\install | started | 0000-00-00 00:00:00 |
  4. Delete the task from the longtasks table using id from step 3:
    # plesk db "DELETE FROM longtasks WHERE id=56"
  5. Delete entries from the longtaskparams table using id from step 3:
    # plesk db "DELETE FROM longtaskparams WHERE task_id=56"
  6. Stop the process that manages the stuck task:
    # pkill -f task-async-executor
Cancelling all stuck tasks
  3. Delete entries from the longtaskparams table:
    # plesk db -Ne "SELECT id FROM longtasks WHERE status <> 'done'" | while read i; do plesk db "DELETE FROM longtaskparams WHERE task_id=$i" ; done
  4. Delete entries from the longtasks table:
    # plesk db "DELETE FROM longtasks WHERE status <> 'done'"
  5. Stop the process that manages the stuck task:
Windows Server
  1. Connect to your Plesk server via RDP.
  2. Start a command prompt as an Administrator.
  3. Create a backup of the Plesk database:
    C:\> plesk db dump > C:\psa_dump.sql
  4. Find the stuck process:
    C:\> plesk db "SELECT id,type,status,finishTime FROM longtasks WHERE status <> 'done'"
  5. Delete the task from the longtasks table using id from step 4:
    C:\> plesk db "DELETE FROM longtasks WHERE id=56"
  6. Delete entries from the longtaskparams table using id from step 4:
    C:\> plesk db "DELETE FROM longtaskparams WHERE task_id=56"
4 comments
Date Votes
  • thank you so much for sharing
  • This ensured I could remove the stuck task from the queue, but when I go to run the task again (ie: remove a subscription), it just gets stuck again... tried the steps to clear the lock manager, but no difference :(
  • I have done all the steps, but I still have problems
    Thanks for your help
    1
  • # pkill task-async-executor
    produced the following error message on ubuntu 24.04:
    pkill: pattern that searches for process name longer than 15 characters will result in zero matches
    Try `pkill -f' option to match against the complete command line.
    Other than that, it was definitely helpful and to the point.
