- Plesk for Windows
Plesk fails to add new domains, and returns this error
Error: ProtDir_IIS::update() failed: Add Protected Directory failed: Filename: \?\C:\Inetpub\vhosts\example.com\httpdocs\web.config Error: The configuration section 'system.webServer/pleskProtectedUrls' cannot be read because it is missing a section declaration In module
Plesk repair fails
"%plesk_cli%\\repair.exe" --synchronize-protected-directories-storage
The system cannot find the path specified.
C:\>cd %plesk_cli%
Missing entries in applicationHost.config because plesk-urlprotection was installed incorrectly. This can happen due to hardware glitches, or network errors.
Add the missing lines to the config file.
Connect to the server via RDP
Backup
C:\Windows\System32\inetsrv\Config\applicationHost.config -
Open
C:\Windows\System32\inetsrv\Config\applicationHost.configand add the missing lines (in bold below) into the appropriate sections:<configuration>
<configSections>
<sectionGroup name="system.webServer">
<section name="pleskProtectedUrls" overrideModeDefault="Deny" />
</sectionGroup>
</configSections>
</configuration><system.webServer>
<globalModules>
<add name="PleskUrlProtectionModule" image="%windir%\System32\inetsrv\pleskurlprotection.dll" />
</globalModules>
</system.webServer>
