Websites hosted in Plesk that are configured to be served by Apache are loading fine over HTTP, but display an error that is similar to the following in browsers when opened via HTTPS:
CONFIG_TEXT: 502 Bad Gateway nginx
CONFIG_TEXT: ERR_CONNECTION_REFUSED
The following error message appears at Domains > example.com > Dashboard > Logs or in the domain's
/var/www/vhosts/system/example.com/logs/proxy_error_log:CONFIG_TEXT: connect() failed (111: Connection refused) while connecting to upstream, client: 203.0.113.2, server: example.com, request: "GET / HTTP/2.0", upstream: "https://192.0.2.2:7081/", host: "example.com"
The ssl.conf file that has ssl_module configuration is either corrupted or not included into Apache configuration. As a result Apache is not listening on port 7081 (when nginx is enabled in Tools & Settings > Services Management) or 443 port (when nginx is disabled in Tools & Settings > Services Management) and therefore cannot handle any incoming HTTPS connections:
on CentOS/RHEL-based distributions
# netstat -tunap | grep httpd
tcp 0 0 0.0.0.0:7080 0.0.0.0:* LISTEN 2647/httpd -
on Debian/Ubuntu-based distributions
# netstat -tunap | grep apache
tcp6 0 0 :::7080 :::* LISTEN 763/apache2
Restore the ssl.conf file and make sure it is loaded:
- Connect to your Plesk server via SSH.
Make sure that the
conf.ddirectory is included in Apache configuration:# grep IncludeOptional /etc/httpd/conf/httpd.conf
IncludeOptional conf.d/*.confIf no output is returned or the line has a hash sign "#" at the beginning, open the file
/etc/httpd/conf/httpd.confin any text editor (for example, vi editor) and add/uncomment the mentioned line. -
Verify that nginx is enabled:
# plesk sbin nginxmng --status
EnabledIf it is disabled, enable it:
# plesk sbin nginxmng --enable
Restore the default
ssl.conffile:3.1. Download the file for your OS and unzip it:
CentOS / RHEL / CloudLinux 8 and 9
# wget https://cpanel.zendesk.com/hc/article_attachments/12377382019607 -O ssl_conf_8.zip
# unzip ssl_conf_8.zip
CentOS / RHEL / CloudLinux 7
# wget https://cpanel.zendesk.com/hc/article_attachments/12377433751447 -O ssl_conf_7.zip
# unzip ssl_conf_7.zip
3.2. Rename the original file, if exists:
# mv /etc/httpd/conf.d/ssl.conf /etc/httpd/conf.d/ssl.conf.old
3.3. Put the file in the
conf.ddirectory:# mv ssl.conf /etc/httpd/conf.d/
Restore SELinux context of the file:
# restorecon /etc/httpd/conf.d/ssl.conf
Restart Apache:
# service httpd restart
Verify that Apache is now listening on port 7081:
tcp 0 0 0.0.0.0:7080 0.0.0.0:* LISTEN 17817/httpd
tcp 0 0 0.0.0.0:7081 0.0.0.0:* LISTEN 17817/httpd
Create two symbolic links:
# ln -s /etc/apache2/mods-available/ssl.conf /etc/apache2/mods-enabled/ssl.conf
# ln -s /etc/apache2/mods-available/ssl.load /etc/apache2/mods-enabled/ssl.load -
Restart Apache:
# service apache2 restart
tcp6 0 0 :::7080:::* LISTEN 2462/apache2
tcp6 0 0 :::7081:::* LISTEN 2462/apache2
