Articles in this section
Can't issue or reissue Let's Encrypt certificate in Plesk: Timeout during connect (likely firewall problem) / Error getting validation data
Plesk for Linux kb: technical ext: le
  • Plesk for Linux
  • Can't issue or reissue Let's Encrypt certificate for a domain or the Plesk panel hostname, while receiving an error that is similar to the following:
    Detail: Fetching http://example.com/.well-known/acme-challenge/do75fK79n_uF9JimlezVpQQQfmvHaOVd7T8cjZKVvWk: Timeout during connect (likely firewall problem)
    Error: Could not issue a Let's Encrypt SSL/TLS certificate for example.com. Authorization for the domain failed.
    Invalid response from https://acme-v01.api.letsencrypt.org/acme/authz/dlJ9iUsYRM51xlzLkS8KpRJYccRh1yKRUJEPgLMoRFc.
    Type: urn:acme:error:connection
    Status: 400
    Details: Fetching https://example.com:8443/.well-known/acme-challenge/44DVtYx2WBKaujKCYO7tOxZ4nS2-m_-Ci5dLoQw0X34 Error getting validation data
    An SSL / TLS certificate could not be issued for example.com
    The SSL / TLS Let's Encrypt certificate could not be issued for example.com. Authorization error for the domain.
    Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/xxxxxx.
    Type: urn: ietf: params: acme: error: connection
    Status: 400
    Detail: Fetching http://example.com/.well-known/acme-challenge/DOgtM-HLdDLxfaGej39Fip168f6njHhwot47XuyGANo: Error getting validation data
    Could not issue an SSL/TLS certificate for example.com
    Details
    Could not request a Let's Encrypt SSL/TLS certificate for example.com.
    Go to http://example.com/.well-known/acme-challenge/jIdPOz-AJnOaU8bJUgwh50yrgPNeW-hBvpm-rnonHl8
    and сheck if the authorization token is available.
    If it is, try to request the certificate again. If the token is not available, there may be an issue with your DNS configuration.
    Your domain in Plesk is hosted on the IP address(es): 2001:db8:f61:a1ff:0:0:0:80, but the DNS challenge used another IP: 203.0.113.2.
    Make sure that the IP address(es) specified in the domain's DNS zone match the IP address(es) the domain is hosted on.
    If it does not help or if you cannot find an issue with your DNS configuration, use this KB article for troubleshooting.
    Despite the fact that this error message suggests DNS issues, it's actually displayed if port 80 is inaccessible too. The error message will be reworked to be more clear in scope of #EXTLETSENC-1235
  • The related domain itself resolves to the correct Plesk server IP address via port 443 (HTTPS)
  • Opening the site in a browser via HTTP may display an error that is similar to the following:
    This site can’t be reached
    ERR_CONNECTION_TIMED_OUT
    Not Found
    HTTP Error 404. The requested resource is not found.
Port 80 (HTTP) for the server IP address is filtered by a firewall that resides on the server or on a level above it and a connection to the web server directory and the Let's Encrypt validation token via that port is not possible:
# curl http://example.com/.well-known/acme-challenge/q3HovILzhuoPvjNiUNP_m1flsnpkK5wJ9bQwEvXwexs
<!DOCTYPE html>
<html>
<head>
<title>401 Authentication required</title>
</head>
<body>
<h1>Error 401 Authentication required</h1>
<p>Authentication required</p>
<h3>Guru Meditation:</h3>
<p>XID: 0107325</p>
<hr>
<p>Varnish cache server</p>
</body>
</html>
# nmap -Pn -p80 example.com
PORT STATE SERVICE
80/tcp filtered http
Note: Let's Encrypt validation servers can only use the HTTP-01 challenge while establishing a connection to the target validation token via port 80 (HTTP protocol), which can be confirmed on the following page of the Let's Encrypt documentation:
HTTP-01 challenge | Challenge Types - Let's Encrypt
Open the web server port 80 for the server IP address in all of the used firewall solutions.
Additionally, if you are using an external DNS service (such as Cloudflare) for the related domain, make sure traffic over port 80 and HTTP for the domain is also configured to reach the exact same web server that traffic over port 443 and HTTPS reaches.
Note: If the issue persists, contact the ISP, hosting provider, or network administrator for assistance locating and opening the block.
2 comments
Date Votes
  • Hello,
    I have this problem
    port 80 is open.
    Tried to reissue the certificate with disabled plesk firewal but no success.
  • Same problem, I have the default firewall rules (WWW rule is accept) but letsencrypt time's out. The .well-known is accessible via the url, I can see the non https go in the log with a 301, so something in the firewall is blocking let's encrypt (and only let's encrypt) on https
    It will only work if I disable the firewall. Could plesk have a look because this is a bug in the default rules
