How to enable remote access to PostgreSQL databases hosted in Plesk?
- Connect to your Plesk server via SSH.
Modify
postgresql.conf:2.1. Open the file
/var/lib/pgsql/data/postgresql.confin a text editor. In this example, we are using vi editor:# vi /var/lib/pgsql/data/postgresql.conf
2.2. Add the following line at the end of the file:
CONFIG_TEXT: listen_addresses = '*'
2.3. Save the changes and close the file.
Modify
pg_hba.conf:3.1. Open the file
/var/lib/pgsql/data/pg_hba.confin a text editor:# vi /var/lib/pgsql/data/pg_hba.conf
3.2. Add the following line at the end of the file:
CONFIG_TEXT: host samerole all 203.0.113.2/32 md5
where:
- 203.0.113.2/32 - a remote IP address from which connection is allowed. To allow connections from any IP address, specify 0.0.0.0/0.
- md5 - authentication method, which requires the client to supply a double-MD5-hashed password for authentication. To learn more about authentication methods, visit this PostgreSQL documentation page.
3.3. Save the changes and close the file.
Restart PostgreSQL service to apply the changes:
# service postgresql restart
Get PosgreSQL release version to identify the installation path:
# psql -V
psql (PostgreSQL) 14.5 (Ubuntu 14.5-0ubuntu0.22.04.1)In this example, PosgreSQL release version is 14, so the installation path will be
/etc/postgresql/14/. -
Modify
postgresql.conf:3.1. Open the file
/etc/postgresql/14/main/postgresql.confin a text editor. In this example, we are using vi editor:# vi /etc/postgresql/14/main/postgresql.conf
Modify
pg_hba.conf:4.1. Open the file
/etc/postgresql/14/main/pg_hba.confin a text editor:# vi /etc/postgresql/14/main/pg_hba.conf
4.2. Add the following line at the end of the file:
where:
4.3. Save the changes and close the file.
Hello
To make the remote access work from the Plesk Panel this is my setup
Step 1: edit postgresql.conf change the line to:
Step 2: add the following lines in pg_hba.conf:
Step 3: In the Plesk Admin panel. Change the firewall service for PostgreSQL server to DENY.
Now when you make a user there you can specify for each database the remote access. Every change needs to be applied in the Firewall page.
