Articles in this section
Subscription expiration date is not changed for existing subscriptions after changing it in a service plan in Plesk interface
kb: bug Plesk for Windows Plesk for Linux ABT: Group B
  • Plesk for Linux
  • Plesk for Windows
If an expiration date is changed for a service plan in Service Plans > service plan name > Resources > change the Expiration date to the required date > Update & Sync , it is not changed for already created subscriptions under this service plan.
As of now, it is expected behavior and considered as the product improvement with ID PPPM-138 .
Use one of the following workarounds:
  1. In Plesk interface:
    Change the expiration date of the subscription in Subscriptions > example.com > Customize menu. As a result, the subscription will be locked.
    Note: such locking is known as the product improvement with ID PPPM-7481 .
    Unlock subscription using Subscriptions > example.com > Unlock & Sync . As a result, everything will be synchronized except expiration date - it remains customized.
  2. Directly on the server when connected using SSH .
    Execute the following commands:
    # mysql -uadmin -p`cat /etc/psa/.psa.shadow` psa -e"select name from domains where id in (select object_id from Subscriptions where id in (select subscription_id from PlansSubscriptions where plan_id in (select id from Templates where name='Example Plan')));" | grep -v "name" > /tmp/webspaces.list
    # while read l; do /usr/local/psa/bin/subscription_settings -u $l -expiration 1970-01-01; done < /tmp/webspaces.list
    These commands will change the expiration date for all subscriptions under the service plan Example Plan to 1970-01-01.
1 comment
Date Votes
  • What should be the equivalent command line for Windows?, this could be deciphered however, this should be stipulated too for Windows Command Prompt.
    1
