- Plesk for Windows
How to create several mailboxes in Plesk at once using a single command or a script in the command line?
Create a file
mail.txtusing any text editor with a list of mail addresses and passwords for it:CONFIG_TEXT: example1@example.com password
example2@example.com password
exampleN@example.com passwordNote: Make sure that passwords comply with the current Password Strength Policy
Follow the instructions below for creating mailboxes by the using the
mail.txtfile you have generated:For Linux-
Download the attached script by executing the following command:
# wget https://support.plesk.com/hc/en-us/article_attachments/12377375244567/createmail_.tar.gz
Unpack the downloaded archive:
# tar -zxvf createmail_.tar.gz
Execute the script towards the
mail.txtfile created on step 2:# ./createmail.sh mail.txt
For Windows-
Execute the command below to create mailboxes from by using the
mail.txtlist created on step 2:Note: In the example below,
mail.txtfile exists inC:\mail.txt. Adjust the path to themail.txtfile if requiredC:\> for /F "tokens=1,2 delims= " %i in (c:\mail.txt) do plesk bin mail.exe -c %i -passwd %j -mailbox true
Note: Other options like
-mbox_quota,-aliases,-forwardingetc., can be added to the commandplesk bin mailin the script. For details on using these options, check the documentation articles: for Linux and for Windows. -
The file download ist not found (404).
content:
Hello Roger,
The link has been updated. Thank you for bringing this to our attention!
