- Plesk for Windows
Is it possible to create custom branding for a reseller? For example:
- Change the login URL to
https://cp.reseller.com:8443 - Change the login page's look for a particular URL
- Change the Plesk theme and appearance for logged-in customers
It is possible to create custom branding for resellers, with a few limitations.
All domains that point to Plesk can be used as a login URL by adding port 8443 (i.e.
https://example.com:8443).Note: This will show a certificate warning unless the domain is added to the panel certificate; vote for this feature to be implemented.
Branding and logos for the panel and log in screens can be customized in Tools & Utilities > Plesk Branding when logged in as a reseller.
For a detailed guide, please review: Reseller's Guide: Changing Branding and Interface Settings. -
Plesk login screen logos can be edited, and some color scheme options are available: Administrator's Guide: Choosing the Color Scheme.
i can see the plesk panel logo branding is available for resellers but the login url ?
but is it possible to have different login urls for different resellers
example
if i have 3 resellers
r1.abc.com, r2.abc.com, r3.abc.com will i be able to add the login url for https://r1.abc.com/login_up.php
and respectively https://r2.abc.com/login_up.php and https://r3.abc.com/login_up.php
alagappan karthikeyan They are automatically available, but only over port 8443; for example, r1.abc.com:8443/login_up.php, and so on. If you'd like to customize them, please vote for the feature request: https://plesk.uservoice.com/forums/184549-feature-suggestions/suggestions/6640242
