Articles in this section
How to list databases with their subscription/domain/owner using a SQL query in Plesk
Plesk for Windows kb: how-to Plesk for Linux ABT: Group B
  • Plesk for Linux
  • Plesk for Windows
How to list databases with their subscription/domain/owner using a SQL query in Plesk?
  1. Connect to a Plesk server via SSH/RDP.
  2. Run one of these commands:
    • This SQL query lists all databases with corresponding subscriptions and customers.
      # plesk db "select db.name as 'Database',d.name as 'Subscription',c.pname as 'Owner',c.login as 'Customer Username' from data_bases db,domains d,clients c where d.cl_id=c.id and db.dom_id=d.id"
      The output will look as follows:
      MYSQL_LIN: +----------------+---------------+---------------+----------------+
      | Database       | Subscription  | Owner         | Owner Username |
      | joomla_7       | joomla.tld    | Administrator | admin          |
      | wordpress_a    | wordpress.tld | Administrator | admin          |
      | db_example.com | example.com   | John Doe      | jdoe           |
      | db_example.net | example.com   | John Doe      | jdoe           |
    • This SQL query lists all databases that have the option "Related to" defined in Plesk. If it is not set, database will not appear in the list. Please note that this query does not list databases that were created together with applications via the Plesk Applications menu.
      # plesk db "select db.name as 'Database', d.name as 'Related to' from data_bases db, domains d, dom_param p where d.id=p.dom_id and p.val=db.id and p.param='lastDatabaseSelectedId'"
      MYSQL_LIN: +----------------+-------------+
      | Database       | Related to  |
      | db_example.net | example.net |
1 comment
Date Votes
  • Same command but showing the databaser server. A must have if you have external database servers:
    plesk db "select db.name as 'Database', d.name as 'Subscription',c.pname as 'Owner',c.login as 'Customer Username', dbs.host as 'Database Server' from data_bases db,domains d,clients c,DatabaseServers dbs where d.cl_id=c.id and db.dom_id=d.id and db.db_server_id=dbs.id"
