- Plesk for Windows
How to hide some IP addresses from the list in Tools & Settings > IP Addresses.
Install Panel.ini editor extension to manage Plesk settings: Home > Extensions
Open extension and under the "Editor" tab add the following lines at the end of the file:
CONFIG_TEXT: [ip]
blacklist="<IP addresses to be hidden>"Where <IP addresses to be hidden> is a comma-delimited list of IP addresses you want to hide. You can hide both IPv4 and IPv6 IP addresses. For example:
CONFIG_TEXT: [ip]
blacklist="192.168.1.10, 2002:5bcc:18fd:c:f482:d057:9ccf:993D" - Reread IP addresses at Plesk > Tools & Settings > IP Addresses > Reread IP.
Connect to the server via RDP.
Open file
. If the file does not exist copy it from%plesk_dir%admin\conf\panel.ini.sample
Add the following lines at the end of the file:
CONFIG_TEXT: [ip]
blacklist="<IP addresses to be hidden>" -
Reread IP addresses by running the command in CMD:
C:\> plesk bin ipmanage --reread
CONFIG_TEXT: [networkInterfaces]
blacklist=eth
