Articles in this section
Plesk is not accessible with error 500: The FastCGI process exited unexpectedly, error code 0x00000000
Plesk for Windows kb: technical
  • Plesk for Windows
  • Plesk is not accessible:
    CONFIG_TEXT: HTTP Error 500.0 - Internal Server Error
    C:\Program Files (x86)\Plesk\admin\engine\php-cgi.exe - The FastCGI process exited unexpectedly
  • If try accessing Plesk directly on the server while connected to it over RDP, the following detailed information is shown:
    CONFIG_TEXT: Detailed Error Information:
    Module FastCgiModule
    Notification ExecuteRequestHandler
    Handler PleskEngine-FastCGI-php
    Error code 0x00000000
    Requested URL https://localhost:8443/index.php
    Physical Path C:\Program Files (x86)\Plesk\admin\htdocs\index.php
    Logon Method Anonymous
    Logon User Anonymous
  • The application pool PleskControlPanel and the site pleskcontrolpanel are started in IIS.
  • Repairing Plesk site using Plesk Reconfigurator does not help as well.
PHP which is used for serving Plesk site (located in the directory %plesk_dir%admin\engine) is corrupted.
  1. Connect to the server using RDP.
  2. Back up the directory %plesk_dir%admin\engine.
  3. Locate or download the necessary MSI file which contains Plesk's PHP files.
    For example, for Plesk Obsidian 18.0.42 this file is C:\ProgramData\Plesk\Installer\cache\pool\regular\PLESK-WIN_18.0.42_8472\dist-windows\plesk-engine.msi (or C:\ParallelsInstaller\parallels\pool\regular\PLESK-WIN_18.0.42_8472\dist-windows\plesk-engine.msi) and can be downloaded from https://autoinstall-win.plesk.com/PANEL-WIN_18.0.42/dist-windows/plesk-engine.msi.
  4. Create a directory for extracting the files from MSI (for example, C:\tempMSI).
  5. Unpack the MSI file found in step 3:
    C:\> msiexec /a C:\ProgramData\Plesk\Installer\cache\pool\regular\PLESK-WIN_18.0.42_8472\dist-windows\plesk-engine.msi /qb TARGETDIR=C:\tempMSI
  6. Copy all files from the directory C:\tempMSI\Program Files\Parallels\Plesk\admin\engine to the directory %plesk_dir%admin\engine with replacing the already existing files.
