Articles in this section
How to activate/suspend a subscription in Plesk?
Plesk for Windows kb: how-to Plesk for Linux ABT: Group A Ideal
  • Plesk for Linux
  • Plesk for Windows
How to change subscription or domain status, for example, activate or suspend it?
This can be done in any of the two following ways:
Click on a section to expand
Activating/suspending subscriptions or domains via Plesk
  1. Log into Plesk
  2. Go to Subscriptions or Domains > Select subscriptions to change > click on Set Status:
  3. Go to Subscriptions or Domains > example.com and click on Activate or Suspend in the Hosting menu on the right sidebar.
Activating/suspending subscriptions or domains via a command-line interface
To activate the domain, the following command can be used:
# plesk bin site --on example.com
To disable the domain, the following command can be used:
# plesk bin site --suspend example.com
To activate the subscription, the following command can be used:
# plesk bin subscription --webspace-on example.com
Note: More information on the options used by the Plesk utilities option site can be found here: Reference for Command-Line Utilities: site: Sites
