The following Plesk Anti-spam tools are used, however, incoming spam messages are still delivered:
- SpamAssassin Spam Filter
- DKIM, SPF, and DMARC Protection
- DNS Blackhole Lists
- Premium Antivirus for Servers
- Server-wide Blacklist
- Greylisting
The spam filter detection capabilities are not optimized for the spam that is incoming.
The following measures can be applied for spam filter optimization:
Decrease spam filter sensitivity (decreasing the number increases the strictness of the filter):
For one mailboxNote: it is possible to edit spam filter sensitivity for the particular mailbox if only the Apply individual settings to spam filtering checkbox is enabled at the Plesk > Tools & Settings > Spam Filter page and the SpamAssassin component for Plesk is installed.
Go to Plesk > Domains > example.com > Dashboard > Mail > Mail Accounts > johndoe@example.com > Spam Filter tab > Press on the Show Advanced Settings link.
Adjust the Spam filter sensitivity and press the Apply button to apply changes.
Server-wide-
Go to Plesk > Tools & Settings > Spam Filter page.
Note: The SpamAssassin component for Plesk must be installed
Adjust the Required score and press Apply.
Train SpamAssassin by using the steps in the following article:
Consider using premium anti-spam tools, such as the following:
Lock spammer mailboxes by applying the solution from the following article:
