Articles in this section
Various Plesk operations fail: error setting certificate verify locations: CApath: none
Plesk for Windows Plesk for Linux kb: technical ABT: Group A
  • Plesk for Windows
  • Plesk for Linux
  • An error like these appears in the extensions catalog, backup scheduler, during Plesk updates, or while running the Daily Maintenance task
    error setting certificate verify locations: CAfile: C:\Program Files (x86)\Plesk\admin\conf\cacert.pem CApath: none
    Internal server error
  • Installing WordPress using the Applications menu fails
    Error: The following error has occurred during the download of application:
    HTTP Error (0) https://cdn.apscatalog.plesk.com/all-app/WordPress.org/WordPress/5.2.1-273.aps?packager=Plesk
    Sharing Violation
The errors above may cause these symptoms
  • WordPress packages that are 0 size in %plesk_dir%var\modules\wp-toolkit\packages
  • Domain log files larger than the log rotation limit
The CA certificate, cacert.pem, is corrupted or missing, which prevents connections from being established.
Download and install the missing file.
Windows
  1. Connect to the server over RDP
  2. Download cacert.pem from the cURL website: http://curl.haxx.se/ca/cacert.pem
  3. Place the file inside %plesk_dir%admin\conf.
  4. Make sure that these directives in %plesk_dir%admin\conf\php.ini have the right path to cacert.pem
    curl.cainfo="C:\Program Files (x86)\Plesk\admin\conf\cacert.pem"
    openssl.cafile="C:\Program Files (x86)\Plesk\admin\conf\cacert.pem"
Linux
  1. Connect to the server over SSH
  2. Run this command to download and install the CA certificate from the official cURL website
    # wget https://curl.haxx.se/ca/cacert.pem && mv cacert.pem /etc/pki/ca-trust/extracted/pem/tls-ca-bundle.pem
