Articles in this section
Options missing in Tools & Settings after upgrading to Plesk Obsidian
Plesk for Linux kb: technical ABT: Group B
  • Plesk for Linux
  • Plesk for Windows
Several options, such as DNS Template and FTP Settings, are missing from Tools & Settings after upgrading to Plesk Obsidian.
Restricted mode is enabled
For Linux
  2. Run the following command to disable Restricted Mode
  • If you have a Web Pro or Web Host license:
    # plesk bin poweruser --off -simple false -lock false
  • If you have a Web Admin license:
    # plesk bin poweruser --on -simple false -lock false
For Windows
  1. Connect to the server via RDP
  2. Start a command prompt as Administrator
  3. Run the following command to disable Restricted Mode
