Plesk for Windows
Plesk for Linux
kb: technical
- Plesk for Windows
Is it possible to share the same Document root between two domains in Plesk?
In order to share example.com's document root with example.net, both domains should be created under the same Subscription.
The general steps to achieve such a setup are the following:
Go to Subscriptions > Add Subscription and create a Subscription
example.com -
After the Subscription is created, go to Subscriptions > example.com.
Click on the Add domain button and create the domain
example.netwith the Document root set ashttpdocs:
