- Plesk for Windows
Plesk interface is unresponsive, after some time the following error is shown in a web-browser:
PLESK_INFO: HTTP ERROR 500
PLESK_INFO: The site can't be reached
the connection was reset. -
The following error message appears in the Plesk log
%plesk_dir%admin\logs\php_error.log:CONFIG_TEXT: ERR [panel] Unable to write to stream: fwrite(): send of 4 bytes failed with errno=10054 An existing connection was forcibly closed by the remote host.
This is a MariaDB Connector bug with ID CONC-518.
Until the bug is resolved, apply one of the following temporary workarounds:
Connect to the Plesk server via RDP.
Start Plesk Reconfigurator at Windows Start Menu > Plesk Reconfigurator.
Click Repair Plesk Installation > select Plesk services > click Check.
Open Plesk Services Monitor from Windows Tray.
Select Plesk Management Service and click Restart.
Start Internet Information Service Manager (IIS) and navigate to SERVER_NAME > Application Pools.
Select application pool PleskControlPanel and click Recycle.
