Articles in this section
The PHP session cleaner cron task in Plesk fails: run-parts: /etc/cron.hourly/plesk-php-cleanuper exited with return code 1
Plesk for Linux kb: technical
  • Plesk for Linux
  • Plesk Administrator regularly receives email notifications about the failed plesk-php-cleanuper cron task:
    CONFIG_TEXT: Subject: cd / && run-parts --report /etc/cron.daily
    Message text: run-parts: /etc/cron.hourly/plesk-php-cleanuper exited with return code 1
  • Manual execution of the /etc/cron.hourly/plesk-php-cleanuper task stops after an operation with the /var/lib/php/sessions/ directory:
    # sh -x /etc/cron.hourly/plesk-php-cleanuper
    + [ -e /etc/cron.d/php -a -x /usr/lib/php/sessionclean ]
    + pgrep -f .*/etc/cron.daily/plesk-php-cleanuper$
    + grep -qv 15249
    + renice 19 -p 15249
    + [ -x /usr/lib/plesk-9.0/maxlifetime ]
    + [ -d /var/lib/php/sessions ]
    The exit code of this command is 1:
    # echo $?
    1
The cron script fails to execute becase /var/lib/php/sessions and /var/lib/php directories are missing on the server:
# ls -la /var/lib/php
ls: cannot access '/var/lib/php': No such file or directory
# ls -la /var/lib/php/sessions
ls: cannot access '/var/lib/php/sessions': No such file or directory
  1. Connect to the server via SSH.
  2. Create missing /var/lib/php and /var/lib/php/sessions directories:
    # mkdir /var/lib/php
    # mkdir /var/lib/php/sessions
  3. Set the correct permissions for these directories:
    # chmod 755 /var/lib/php
    # chmod 1733 /var/lib/php/sessions
To verify the execution of the `plesk-php-cleanuper` cron task
  • Execute the task manually:
  • After the execution is finished, check the exit code. It should be 0 which means success:
    # echo $?
