- Plesk Obsidian for Linux
- Plesk Obsidian for Windows
Information
# The support for the following components and features are discontinued in Plesk Obsidian 18.
# Click on the required section to get details on why these features are dropped and recommendations on what to do:
Click on a section to expand
Plesk VPN
- Plesk VPN was a component that allowed setting up an OpenVPN service on a server. However, due to consistently low installation numbers and significant resources needed to update it for compatibility with Plesk Obsidian it has been decided to stop its development.
- What to do? The OpenVPN can be installed and configured manually using official instructions
- To simplify the UX and remove rarely used non-default color schemes, only two color schemes are available since Plesk Obsidian: Obsidian and Onyx.
- What to do? If more color schemes are required, you can take part in our product improvement and create a feature request on the following link via the Submit idea button:
- File Server, also known as File Sharing, was a component that allowed Plesk administrators to share directories on a network directly from the Plesk. Due to the low usage of this component it was decided to drop it.
- What to do? Use a different solution, for example, install SeaFile extension
- Windows 2008 R2 reached the end-of-life on January 14, 2020 and not supported anymore.
- What to do? For those who use Plesk on this OS, we recommend migrating to supported Windows OS using Plesk Migrator
- This used to be an excellent OS, but unfortunately, it’s outdated since April 1, 2019. As we are dedicated to focus our efforts on the latest, most secure OSes recommended by OS vendors, we are dropping Ubuntu 14.04 support.
- What to do? For those who use Plesk on this OS, we recommend migrating to a different OS using Plesk Migrator.
- Replaced the auto-reply function developed by Plesk with native solutions provided by the supported mail servers. This improvement increases email sending and deliverability when DMARC, DKIM, and SPF are used.
- What to do? For details and recommended actions, see the Feature and Deprecation Plan.
- The BIND DNS server has already been deprecated and removed from Plesk for Windows. Due to security and maintenance risks, we are taking steps to ensure that no Plesk servers continue using BIND as of Plesk Obsidian 18.0.70. If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS.
- What to do? We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
- Plesk UserVoice will be deprecated by October 2025. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform, Plesk Productboard. To continue sharing your ideas and feedback, visit https://features.plesk.com.
The Plesk APS Catalog is being fully deprecated due to low usage and outdated technology.
Deprecation timeline:
- In Plesk Obsidian 18.0.75, the following applications are removed from the catalog: AfterLogic WebMail Lite, AfterLogic WebMail Pro, Moodle, Drupal, MediaWiki, phpBB, osTicket, TYPO3.
- In Plesk Obsidian 18.0.77, the APS Catalog has been deprecated and removed from all Plesk versions.
What this means: Already installed applications will continue working, but Plesk will no longer provide support for APS applications.
Recommended alternatives:
- Use WP Toolkit for WordPress installations.
- Use Joomla Toolkit for Joomla installations.
- For other applications, follow their official installation guides.
- The following SDK functionality was deprecated in Plesk Obsidian 18.0.69: implementation of the
EventListenerinterface without thefilterActionsmethod. Starting from Plesk Obsidian 18.0.71, it will be mandatory to implement thefilterActionsmethod of theEventListenerinterface. See more details.
- As of November 2025, AWstats is no longer being maintained. For that reason, it will be deprecated in Plesk Obsidian 18.0.78 and removed for new installations in Plesk Obsidian 18.0.79.
Note: if AWStats was present prior to update to 18.0.79, it will remain available after update. - What to do? On Plesk for Linux, support for GoAccess will be introduced simultaneously with the deprecation of AWStats. On Plesk for Windows, Webalizer can be used as an alternative to AWStats.
- Support for Debian 11 was dropped in Plesk Obsidian 18.0.81. Starting with Plesk Obsidian 18.0.82, Debian 11 is removed from the list of supported operating systems, and new Plesk Obsidian releases are no longer published for it. Debian 11 has reached its end-of-life (vendor EOL date - August 31, 2026).
- What to do? If you are running Plesk Obsidian on Debian 11, we recommend that you dist-upgrade those servers to Debian 12 using our dist-upgrade tool, or migrate the hosted domains to Plesk Obsidian servers running a supported OS.
- The support for XML RPC protocol versions earlier than 1.6.9.1 has been deprecated and removed in Plesk Obsidian 18.0.82. Requests that use an earlier protocol version now result in an error.
- What to do? We strongly recommend that you update all existing integrations using earlier versions of the XML RPC protocol to comply with the version 1.6.9.1 specification.
Warning: Re-enabling XML RPC protocol versions earlier than 1.6.9.1 is not secure and is not recommended. Use it only temporarily, until your integrations are updated.
To temporarily enable the support for XML RPC protocol versions earlier than 1.6.9.1:
- Create a backup copy of the
panel.inifile. -
Add the following lines to the
panel.inifile (see how to edit Plesk panel.ini):CONFIG_TEXT: [api]
oldVersionsSupported = true
- To keep you safe, we’ve removed a number of deprecated and insecure key generation algorithms (RSAMD5, DSA, NSEC3DSA, ECCGOST, RSASHA1, and NSEC3RSASHA1) from the DNSSEC extension. ED25519 is now the default algorithm in Plesk for Linux, and ECDSAP256SHA256 in Plesk for Windows.
- Node.js 20 was removed following its end-of-life on April 30, 2026. It can no longer be installed via Plesk.
- Horde Webmail was deprecated in Plesk Obsidian 18.0.64. It is no longer maintained, and will receive no further updates or security fixes. On servers where Horde is installed, a warning is shown to the administrator after every Plesk update (excluding hotfixes), the first time they log in to Plesk.
- What to do? We strongly recommend switching to a different webmail client: How to change webmail for a domain / all domains in Plesk. For details, see the Feature Deprecation Plan.
- The Social Login extension has been deprecated and will be removed in Plesk Obsidian 18.0.84 (January 2027). After that, it will no longer be possible to log in to Plesk with a Google, Facebook, or GitHub account, or with a passkey. Plesk usernames and passwords, as well as logging in with a WebPros Account, are not affected.
- What to do? See How to log in to Plesk after the Social Login extension is removed and the Feature Deprecation Plan.
- The Plesk Mobile apps for iOS and Android and the Plesk Mobile Center extension have been deprecated, and are no longer available for new installations. In Plesk Obsidian 18.0.84 (January 2027), the Plesk Mobile Center extension will be removed from servers during the upgrade, and the Plesk Mobile apps will lose their server management features.
- What to do? See How to manage Plesk from a mobile device after Plesk Mobile is retired and the Feature Deprecation Plan.
Additional information
Feature Deprecation Plan: https://docs.plesk.com/release-notes/obsidian/deprecation-plan/
