Articles in this section
How to enable OCSP Stapling and HSTS for Plesk interface?
kb: how-to Plesk for Linux
  • Plesk for Linux
This functionality is yet to be implemented in Plesk. Vote for the corresponding feature suggestion at Plesk Feature Portal..
Top-ranked suggestions are considered to be included in future Plesk versions.
The following workaround can be applied:
  1. Connect to the server using SSH.
  2. Open the file /etc/sw-cp-server/conf.d/plesk.conf for editing via a command-line text editor and add the following content within its server section:
    add_header Strict-Transport-Security "max-age=31536000" always;
    ssl_stapling on;
    ssl_stapling_verify on;
    resolver 8.8.4.4 8.8.8.8 valid=300s;
    resolver_timeout 10s;
    Note: in order to enable HSTS without OCSP Stapling only add the add_header line to the file above
  3. Restart sw-cp-server to apply changes:
    # service sw-cp-server restart
1 comment
Date Votes
  • I use latest Plesk Obsidian, and this does not work.
