How to enable OCSP Stapling and HSTS for Plesk interface?
This functionality is yet to be implemented in Plesk. Vote for the corresponding feature suggestion at UserVoice portal.
Top-ranked suggestions are considered to be included in future Plesk versions.
The following workaround can be applied:
Connect to the server using SSH.
Open the file
/etc/sw-cp-server/conf.d/plesk.conf
for editing via a command-line text editor and add the following content within itsserver
section:add_header Strict-Transport-Security "max-age=31536000" always;
ssl_stapling on;
ssl_stapling_verify on;
resolver 8.8.4.4 8.8.8.8 valid=300s;
resolver_timeout 10s;Note: in order to enable HSTS without OCSP Stapling only add the
add_header
line to the file above -
Restart sw-cp-server to apply changes:
# service sw-cp-server restart
1 comment
I use latest Plesk Obsidian, and this does not work.
